Jewell County KS | Thanks for the info Kevin. I checked out your website very informative.
Actually the walls will be lined with steel after the insulation(no matter what I use) so the paint deal is a mute point. The building also has some bubble insulation under the tin that I thought would work but I don't think it's gonna cut the mustard.
As for the effective R value... he was very up front with that statement and said that it was not a valid way of rating the stuff.
Does the R-7 per inch sound right ? | |
