| Gene hover's around SE VA, NE NC mostly. he flies out of a local private strip near me and does extensive work for Coastal Chemical outa Courtland, Va branch location.
guy named Craft......First State Applicators is from De but works mostly in NC/VA area to my knowledge......he does work for the local CPS's. you may check with your local CPS to see if Craft will also travel up that way.
outa the 3 local flyboys here in E NC, only 1 is left and he's booked up. the other 2 have moved on tho that great turbo prop in the sky. vi | |
