Posted 10/5/2008 22:22 (#475625 - in reply to #475096) Subject: Re: Baler Fires Hank, in OR
Bonanza, Or
Just got back from a weekend of keeping the state of Nevada green. Mine was one of the balers that the flywheel light was on all the time when the tractor lights were on due to the switch on the baler being WAY out of adjustment. I unplugged the light like was suggested from Hesston. I can see how it could be a problem because of the heat it was generating in a spot where there is quite a bit of fine dust buildup.
Mine baled hay right out of the box except for the bale length adjustment arm. It had to be shimmed so it would fall all the way back down when it was tripped.
I don't understand how Josh's got out of time........did it jump a tooth?
