LeRoy IL | What ever is cheaper. When wet is around $20 per ton than about $1.10 a bu for corn. When you can cut a third of your corn cost down to that it will add up.Of course when they are giving it away its hard to turn down. Hope you will post some pics of your hoop.
Carcass dosent seem t be a problem until around 70% of the diet. But I am just going on a lot of studies that have been done at that level . Know a few that feed at 50% but you need to watch them close at that level depending on how much sulfer they are getting. | |
