Posted 2/11/2024 18:21 (#10619172 - in reply to #10619149) Subject: RE: 350 Cummins small cam excessive whit smoke and running rough
Central ND
Question.
If you can go through the trouble pulling #2 injector, why didn't you swap it with #1? Would have been a whole lot easier then pulling the head if the bad cylinder would have became #1. Also, your eyeballs are generally not going to be able to tell you if you have a bad injector. Just sayin'.
