Posted 3/8/2009 11:13 (#635727 - in reply to #635723) Subject: Re: In-bin drying temps?
Northeast Nebraska and Candelaria Philippines
I don't know what's proper, but we set at 110-120. Also, if you don't have the type that varies the gas flow, you want to set the regulator properly. You want to set it, so it doesn't kick on/kick off often. Ideally, the burner would remain on 100% of the time while maintaining the proper temp.
