| Pretty sure that the XP/HP unlock costs 3000 and the Z+ antenna comes with that price. The RTK unlock then costs an additional 3000 and still uses the same Z+ antenna. Sounds like to me the Z+ antenna really doesn't cost much of anything and so it seems it would be more appropriate to charge 3000 for an RTK unlock and the Z+ antenna or 3000 for an XP/HP unlock and the Z+ antenna or 6000 for both XP/HP and RTK with antenna. However, I believe for those going direct to RTK still get charged 6000. Don't really get it. Might as well go to XP/HP first and then RTK if it's going to cost the same so you have the option of using XP/HP if you want.
