Blue Earth, MN | You may want to consider adding more weight to the front. Had a 4720 with 6 weights and it was still light enough in the front to cause steering problems. We now have 12 weights on a 4730 and it is much better. Also, do you have the self leveling valves or the manual inflated air ride? Our first 4720 did not have the leveling valves and with the injection tanks full it would lean to that side enough to cause it to dog track a little. We spray 10-18 MPH | |
