Buffalo IL | You both may be right and I have been wrong before. I have been trying to find the nutrient analysis for CCDS and haven't yet. IT all depends on if the analysis is Dry Matter or as fed and the % moisture. Seep is too far for me, but at Leroy it is close corn and beef and I don't know where eddie is. 10% Fat dry matter converts to 2% at 80% wet. IT all depends on consumption cattle eat lbs of feed. 48% soybean meal is probably the cheapest protien/lb. I have found it the analysis. eddie your analysis is on a dry matter basis so you need to adjust to the % moisture your CCDS are at. I believe the analysis for Mix 30 is as fed at 60% moisture.
Edited by IL cow man 11/8/2011 20:18
