Lapel, In | Inside wall or outside? Is that mold I see? Kill it with full strength bleach using a squirt bottle. That electrical outlet has got to go and it needs to be on a ground fault circuit in a bathroom. If you are going to use it as a tub, I like to stuff the underside with fiberglass insulation. It will keep the tub water warm longer. I would probably rip it all out and line it with the green wallboard, but I tend to be a bit annal when remodeling. | |
