MN | If you are looking at used loaders try to find a 725, I have a 720, was on a 4430 now a 4255, really like it. They only fit a 2wd, are designed much like a 148 but seem heavier. It is much easier to see what you are doing without the arms sticking up over the hood. The quick attach buckets are interchangable between the 600s and 700s. The 720 is like a 148 and 725 is like a 158 with longer reach/ higher lift, also higher price if you don't need that. The 721 and 726 replaced the 720/725 for a short time and would also work well however they have a different mounting style and are even harder to find. I can pull 2 pins and 4 hoses and have my 720 off in about 5 mins. Also if you are looking at other makes I have a Miller P-12 for sale that fits deere 2wd in the for sale forum. | |
