Central IL | I was curious as well. I'm running a 7000 6 row with a 5 row splitter behind it with Yetter coulter/combo's on the front 6 with no interference. I just picked up a set of Yetter row cleaners from an older Kinze which mount on the row unit face plate, the same face plate the JD coulters mount to (on some 7000's?) and they appear as they may not run low enough due to interference between the row cleaner arm and the bearing cap on the coulter.
Of course you're not supposed to run regular row cleaners in 15" rows, but I need to see for myself and I needed something to do while it was pouring down rain.
BTW: Welcome aboard jb12string, I see it's your 2nd post, you must not be all bad if you play a 12 string and are a 3rd gen farmer trying notill on a small acreage. | |
