Western illinois | baffle should be on 2 as others have said. are the same tubes plugging all
the time? maybe certain tubes are too long. too much sag could cause a problem.
you have to leave enough to compensate for wing flex though. high humidity may
call for a little talc to absorb moisture. i personally never have used it though.
1250 poncho can cause problems too. i won't put that stuff in my planter. just
some thoughts. i've been there. good luck. | |
