Here is the situation Console ON - self test mode. set at 5mph Cable disconnected at sensor on motor 3 wires at motor red-black 12V+ red-white 7V+ white-black 5V+ Motor (Eaton vane type) no card Speed sensor eaton p/n 201779-001 rev D Continuity check on sensor red-white 9.98 K ohms black-white -open black- red -open I think the sensor IS working, otherwise I would get no rate reading at the console. The valve is set to PWM |
