Camrose, Alberta | "budweiserfarmer" I don't feel that the high/low flow valave is the issue. I do have it all the way open though. I spray right on the threshold, between 25-30 gal/min. I found that when I am spraying 10 gal/ac, 13 mph, through 04 (red) nozzels at 45 psi I can run with the valve all the way closed. In fact I can go a little faster, up until I reach 30 gal/min then I have to open the high/low valve. However when I am spraying 10 gal/ac, 13 mph, through 03 (blue) nozzels at 65 psi I have to have the valve all the way open. And when it was acting up I was running 10.5 gal/ac through 04 (red) nozzels traveling at 14.5 mph at about 60 psi, with the valve all the way open.
"gbfarmer" so you feel it is a communication problem between the two monitors. Mine is the same way, with a GS2 and a brown box.
"Jacob Bolson" I am not sure where I would find that information. | |
