| Like Dap54 stated, curves can be hard on them, or more specificly someone picking up or setting down on the end without being straight. I would make sure my driver was doing a good job on the turnrow.
A dealer once told me that Sloppy planter men keep the bearing people in business. "Losing the ends" can be a problem with drag planters, but are no problem at all if you pay attention to what your doing, which doesn't seem to be the case with alot of my neighbors.
Cottonfarmer, are you sayin' your dealer is going to replace your bearings after 1600 or more acres???? I need that dealer!!!
Edited by conrad 6/30/2008 22:32
