Thinking of adding a semi to a gooseneck fleet, would you do it again?
Poverty acres
Posted 1/22/2024 21:59 (#10588644 - in reply to #10588407)
Subject: RE: Thinking of adding a semi to a gooseneck fleet, would you do it again?
Central SD
Idk how spread out you are but I haul my tractors more then I road them. Just easier to load them on the drop deck and semi to go any distance. Pull the baler or hydraswing with the pickup. Also haul them to load bales. I’m definitely willing to put it on the trailer if it’s 5 miles or more, usually need a ride back anyways
