Posted 5/25/2009 20:24 (#722724 - in reply to #722535) Subject: Re: Need help understanding dryeration
All good advice, but a problem is if you're drying corn that only started at 18 or 19% you probably won't get as much dryeration effect as drying it from 20% or more. I've never found the "17%" rule to be a solid rule if you want to end up at 15%. Have you other guys ?
