| Your strategy is the correct one. You may want to play with the tilt a bit. You should order a couple update kits from me so you can see what performance difference there is in the wet so you know what is possible for the future. Will likely have a couple available on Monday. Shallow, light, fast...The problem with the older units is that they limit the forward speed which in turn limits the amount of "energy" you can get into the soil to break it up. The Curvetine closing wheel should be considered necessary in some of these conditions. | |
