Posted 4/20/2009 02:22 (#686494 - in reply to #685999) Subject: Re: Another air brake question
Somerville, Indiana
Had clearance problems on an R 190 years ago when going to spring brakes. I cut the mounting flange loose from the cam bearing and changed the mounting angle. Wasn't that bad of job.
On the spring brakes not holding, you need to check out your linings, drums, and adjustment.
