South central, Nebraska | I was able to export a file to the Harvest Editor. I made a flow delay correction of 2 seconds and got the internal field map to clean up very well. SMS software will not allow flow delay correction to AFS files.
It would be nice to clean up the beginning and end of each pass. The start/stop delays don't seem to clear up the low flow at the beginning of each pass and the high flow at the end of each pass.
Do you know if it is possible to export the reprocessed file back to SMS. I can't get SMS to import the corrected file back.
TIA | |
