Manitoba | I have a Raven SCS440 sprayer control that I am putting in a Case 9390 to control NH3 on a flexicoil cultivator. The problem that I am having is figuring out the correct cable I need to extend the main console harness. The one that I have is about 10ft or so and isn't long enough to make it to the back of the tractor. This harness plugs into the back of the SCS and has a large square plug and a small round plug on the implement side. The harness on the cultivator side has the large square plug and a 3 pin weatherpack connector. I have two part numbers but need some clarification as to which is the correct one.
24' Extension cable (3 boom) 1-115-0159-857
12' Flow Ext. 115-0159-409
Thanks in advance for any help | |
