| I have a powercast tailboard for the first time this year. We tried cutting wheat tonight, too wet, so we only did about 10 acres. It seems as though there was a much larger percentage of straw coming out the right side of the machine. I open the chopper up and at the rear of the discharge beater there are two adjustable fin's for lack of a better term. One was straight back and the left fin was pointing to the right. Is this causing the straw bias. They are adjustable so I adjusted them to the right, and I will know the results tomorrow. Any other suggestion. I looked through the book, and found nothing about adjusting these fins, although they are clearly adjustable. Your thoughts please. Thanks
Edited by ndarbuckle 8/17/2008 00:50
