Posted 5/3/2008 07:26 (#370354 - in reply to #370205) Subject: RE: Problem with JD planter with VRD
check the number of the gear you enter in the motor configuration, because i use vrd whit e-set kit and i plant exact population i whant and check if you have 1 in the value of the soybean ajust,
