Search Forums | Classifieds (18) | Skins | Language
Using Scepter for volunteer RR corn
don@nebr
Posted 2/24/2008 13:45 (#318156 - in reply to #317259)
Subject: Re: Using Scepter for volunteer RR corn
Used Sceptor one year only,,,two years later could tell where the wash water was applied across the field sideways,,no other variable to explain foot difference in height,,,wash water part was heavier soil so should have been taller but foot shorter instead. NO MORE OF that CRAP!!!HERE!!! Ended up walking the burs out in 110 degree heat index,,it WAS HOT that year!!
I would try Treflan ,,it helps with individual volunteer corn,,and IF you have enough later,treat it with select etc. Sceptor kills soil,period,,,PLUS it acted like fertilizer to the cockleburs which we were after!!SOLID STAND!!!. Treflan or prowl is really cheap for what it does. Saves at least one if not two rup passes here and keeps them clean early,which is MOST important!!
