Posted 4/13/2024 14:32 (#10705341 - in reply to #10705276) Subject: RE: Planter vac motor plumbing
Missouri
is the block / manifold on the tractor a relief valve and is there 3 ports / hoses on it counting the coupler as a hose if so most relief valves also act as a one way check
