campbell - 3/27/2024 13:09
We use a Gandy Orbit Air applicator for granular insecticide. It uses a venturi to suck the insecticide into the airflow then 1" hose to deliver it to the row. They use a metering wheel
(electric or hydraulic driven
) to drop the insecticide into the piece they call a mixing chamber where it is sucked in by the venturi/airflow.
https://www.gandy.net/1-14-plastic-mixing-chamber
If you could find one
(Gandy or Valmar
) for sale on any piece of used equipment
(they were popular for cover crop seeding as well
) near you and go take a look at it you could see how they are made and copy the design pretty easy. In fact the dry fertilizer applicators that deliver to the row with air are a similar design so looking at one of them might help. I don't know anything about air seeders or air flow fertilizer applicators or if they use the venturi principal or a air lock type design.
