Madison Co. Virginia | I've been frustrated with how short of a time they last as well. The contacts either burn, or they fall out of their socket.
Something I have considered, but not done, is to install a magnetic motor starter on the wall near the pressure switch. Run the coil voltage through the pressure switch, so it doesn't have much amperage. Hopefully then, the contacts wouldn't burn up. This still won't do anything for those poorly attached rivets that hold the contact pads in place, though. | |
