Colby, Kansas | JDAMSGURU,
Do you have any idea on what the amp draw for each clutch is and how they are going to handle the cabling. I can't help but think if you have all 24 rows shut off, thats a lot of energized coils and a lot of amp draw.
Thanks
Lucas
Edit: I may be reversed that the clutches are in a "normally open" state and are energized to plant, I don't know, either way the current will be the same at some point.
Edited by LHaag 7/23/2008 22:22
