Parkston, SD | It is possible for the lights to be lit but the green wire on the sensor is the one that sends the signal to the monitor. In a 12 row harness, there are two wires coming from the monitor for each half of the planter one hot and one ground. but each row has its own "signal" wire running from sensor to monitor. They all splice together in that round black connector. Id look there if there's damage to it.
Josh | |
