SEMN | I'm running a 1200 pivot transport for the first year. Getting along fine, but had a question for you guys that are running them. After lowering the planter, do you plant in float? My outer wings were starting to work up as I was going through the field. The dealer said once the planter is down, move the scv to float position. That keeps the wings down, but it seemed a little unusual to me that I would need to run in float to plant. Just was curious if there was some oil leaking back through the system somewhere, and this was the easy fix. | |
