WCIA | That is not a fun job fixing those stupid oil lines but it is possible. If you have no luck removing the bolt on the cylinder ram, then take come-a-long or chain fall and pull the floor back to the retracted position. you should be able to get to everything then. very tight in there and it gets frustrating but it can be done. good luck. ps make sure the tractor scv valve is in the float postion when pulling on the floor | |
