| I have used a honeybee for a number of years and they are cheap to maintain and reliable. The headers made for a combine may not be what you need. There is some made to fit Sp windrowers that don't have the built in hydralic system which the ones for combines have but then they rely on the windrower for floating rather than its own float system as on a combine. I am not sure how well the Schumacher knife system works in green material as the gaurds are made to cut top and bottom but that can be changed. The knife drive is great.
I am not sure which reel system you like but I would not get the type in the top picture as it will wrap at the reel arms in green material. The second is a UII but the ones we use have plastic teeth and work well. | |
