Central Iowa | Just put on a set of martian spiked closing wheels on our planter biggest POS ever seen tring to plant into chiseled ground and cant go 100ft and they plug with a root ball just running no-till culters and the spiked wheels can you run culters and trash wippers both and will the trash wippers keep them from plugging on worked corn on corn also seen alot of kernals on the ground do you need the ketons with the spiked wheels or should we just put the rubber wheels back on TIA | |
