East of the Rockies West of the rest | Im wondering about running a Hydraulic Pump off my 9220 to run the fan on the Air Cart. The corn planter pretty much robs all the hydraulic power for its operations so Im stuck with a bit of a dilemna. Ran it last year with a small Prince Pto pump, it burned up. Finagelled it to work on the outlets but bunged up some due to ground speed and fan being drawn way back down from lack of hyd power when planter is lowered.
Ive got the power on the 9220 cough cough, run a big 1000 pto have a plumbed tank setup over the back wheels and a large cooler on the cart.
Just need a pump. Any ideas? I think it will require around 20 gpm. And it also requires somewhere in the range of 2800 psi. The Prince pump hardly would get the auger to turn under load. So I want to run it just like the tractor. Have a flow valve on the tank and a case drain line in it as well. All set up for go go minus a pump.
Thanks |
