Bonanza, Or | I run mine on auto. I do 4 things differently, I don't go above 20% , I set it to come on at a lower moisture% ,I set my bale weight heavier than actual and I run 4 lb rate instead of 3.
Are you sure you don't have the low rate nozzles installed instead of the high rate?
The biggest problem I see with the system is that the sensors and the application bar are too far apart and you will always have an untreated section in a bale if the moisture is up and down. | |
