Ripley, Ontario Canada | There are a lot of differences in post hole augers. I run a PTO Danuser, but there are other good makes. If you get hydraulic can you run the auger and lift at the same time? Some hydraulic systems can only do one thing at a time, I don't know how well it would work if you can't lift and turn at the same time. I would also get more than a 12 inch auger. And get one more than 48" long, then you don't have to clean the holes right out every time. | |
