NE SD | Steve, If you're using imageevent like Ron, Von, Dutch, and I use, you don't have to do any resizing. All you have to do is load them up in image event and they will automatically be resized for web size. If you go to the bottom of the page, you can click "original" after size to see the photo in full size. You can go in your settings and chose your preferred "web size".....but I stayed with the original settings. I really dislike having to resize photos. When you want to post the photos, in the "html editor" mode, click the little "picture" link next to the "html" link......which happens to be just below the alignment links. Copy the address from the bottom left of the page in image event and past it into the popup window. Original sized "before":
Web sized "after":
