nw pa | any in bin dryer can be influenced by a lot of things.. How many fines ,how thick is the corn. amount of airflow. 25 percent corn has almost twice the water in it as 20 percent so will take longer. drying at 180 though should move things along. If your not comfortable with that number then make the depth less or turn up the heat. Make sure you don't have a pile of fines plugging the whole works up. 100 bu and hour is 2400 a day. Most low temperature bin dryers can not do much more. Probably getting about as good as it gets for now... Will seem like a whole nother dryer when corn comes down to 20 or less. | |
