SW IA | Pat, What was the model of combine that you put these in? I just put a set in our 1460, but haven't been able to try them yet, Beans are a little green still. When you put the impellers in, did you re-balance the rotor? Just curious, I put the rotor in neutral and spun it by hand. It never landed in the same spot and didn't spin the other way when it did stop (Not sure if that is the proper way to do it or not). Thanks, Eric |
