Michigan | I just purchased mojo can the 4 coaxial cables that go up to antennas be cut and add on to if using the same type 316 cable and ends, would like to have some cables permanently strung through cab so would not have to rerun every time move mojo, Leica seems to charge $185 every time need a cable so not sure buying extra cables from Leica would be the answer From reading manual will have to recalibrate every time move from tractor to tractor can the information be stored like the ez 500, seems like Leica is trying to make it very hard to have it for more then one vehicle in my farm operation the only way I can justify the cost is to spread over more then one vehicle, planting tractor, sprayer, combine which are used in different times of year but would like to have it a little easier to do. | |
