Colby, Kansas | Tim,
Thank you for clarifying that on the Deere units, I wasn't aware that's how the three points were used. So if I understand this correctly it generates the two linears from the zero and the low flow, then the low flow and the normal flow,,, where the two intersect is the breakpoint?
You're correct, a lot of people don't understand that the box (any type) is basically worthless unless your willing to make the effort to calibrate. Maybe even worse than worthless as bad data can be worse than no data.
Lucas
