Posted 8/17/2008 22:19 (#437399 - in reply to #437300) Subject: Re: How do you pull your pickups around..towbar ideas please
EC North Dakota
I have a Red Dragon tow hitch on my service PU and use it all the time. Not so much behind implements but use one PU to pull the service PU to the field and then go get implement with other PU. On way home drive service unti to original PU and hook together and go home.
I like the red dragon because as you say it folds flat and out of the way, is fairly easy to hook up, there is some room to hook and the pull ahead and latch and go.
