near Mtl, QC | Ok thanks all for you help, I was able to hook up my ez250 on my AFS2000 (old black box) to be able to do GPS logging. I found out cable needed and everything is connected, the yield monitor is getting GPS signal info of the EZ 250.....nice! Just one thing that I'm not sure if it's ok, it's if I look at the longitude and lattide info, they are not the same as the EZ250. Will it work anyyway? GPS output setting to the EZ250 was 4800 baud, no parity (I could not find a place to put 8 bits). Message selection GGA and VTG ON...rest id OFF.
If I look the first numbers ex 72 degres W they do are the same, but not the rest (tere is about 6 digits).
Thanks in advance! | |
