Millhousen Indiana | is it a YM2000 or AFS2000. YM sill have teh Ag Leader logo, AFS will have the CASE logo. there is a differance. look in your fuse panel under the armrest. if it is an ym2000, there should be a 9pin serial cable labeled "GPS only". it is a pigtale to the large round connector that goes outside the cab. if it is a AFS2000(case branded YM2000) then look in the fuse panel for a 5 pin flat connection. it will be white in color (if its not dust covered) and will probably have a plug in it. you will need a conversion cable from ag leader that goes from a 9 pin serial cable to the 5 pin flat. | |
