| Ronk is the most common site isolation device in our area and I see alot of them on farms. Most common size is 400 amp. They are only rated for 10,000 amps of fault current so in order to pass code in our area you need to have a fusible disconnect upstream from the Ronk. Pretty straight forward to wire, just make sure you bond the enclosure to the neutral/ground in case of a short/ fault. | |
