Posted 6/24/2008 06:37 (#403492 - in reply to #403490) Subject: RE: front axle pivot 4430
The bushing has most likely turned in the support. You have to drop the front end and put new bushings and pins in. It's a pretty simple job if you have a crane and a little harder (but still not bad) with a good floor jack.
