Sunnyside, WA | I installed the whole system myself following the instructions that were sent with it. The cable is installed comming out of the 450 and before the ball valves using a CAN bus system. I actually talked to Raven about being able to control individual sections manually and they told me as long as accuboom is enabled, you cannot control any boom sections manually that accuboom is controlling. The mast switch is the only way to kill them all. Did I put something together wrong?
This is actually one of my issues with accuboom is that you can't overide the system on the first round to not spray waterways, etc. It would be nice to have all the boom section switches in the on position and then be able to shut them off manually if need be.
Edited by J. Sheehan 6/8/2008 14:24
