| If your harness is PF80802 from the PF90420 box that is common for installing on different makes and models, the two pin connector you might be tied into is not the intended location connector. If you do not have an ISO connector, then the connector you are connected has two circuits. A 209 implement signal wire that others have mentioned, and a brown 211 which is a ground speed radar circuit that is found in ISO extension harness. My guess is that you are trying to close the circuit between two signal wires.
This is a simple fix though, remove the black wire of the implement switch extension and ground it to the tractor. Hope I helped. | |
