Posted 3/26/2008 14:18 (#342302 - in reply to #342097) Subject: RE: Houghta3 - did you get the EZ-Boom Master to work?
OK - but that would not be acceptable to our customers.
If you can get to the end of the cable that went to the Raven, I would think there would enough room to insert a pin in #10 and just route that wire to the output side of the foot switch.
Then the EZ-Boom will operate with either its Master or the Floor switch.
